VSF PAM683 side by side with Genuine
Repworld
6,388
1,598
KOT1917
3,396
5,551
Russian federation
Little things, of course, as always, you can find a lot of mri macro photography, but overall, this is a wonderful rep. By
the way, the dots are inserted into the ceramic bezel, and I like the gaps on vsf more. It's a pity there is no comparison on the side by thickness ....
Thanks for sharing!
Reactions: sukwonee
Repworld
6,388
1,598
vS Panerai need more works to be perfect..
KOT1917
3,396
5,551
Russian federation
Yes, it’s clear. Fortunately, there are still enough models that they can try to repeat.I am glad that at least they remain interested in the production of PAMs.
superspark69
3,194
2,258
Sheffield, UK
Biggest issue on this one (despite relative thickness comparisons) is the movement, they used the p9000 clone inside where they would have been better off using a 7750, this has resulted in the CP being too large and incorrect movement operation. The other is the crystal having the fish eye effect whereas the gen does not have the effect.
other than that it is a good looking very wearable version.
Reactions: sukwonee
jcher
1,954
750
Thanks for sharing, I would have liked to see a case thickness comparison
Reactions: miscusi
centrum
533
261
I like this watch. However the VSF's bezel numbering is a little weak. The thickness is the same at 14.5mm according to various TDs' websites. Rep PAM 682 was thicker than the gen, so I am glad this rep exists with correct thickness. Anyone has purchased one?
KOT1917
3,396
5,551
Russian federation
Hello. I think many people bought them, read it better in the thread of the discussion of this model:
https://forum.replica-watch.info/for...625-vsf-pam683
This is a good watch, save for the general downsides of the 42mm subs from VSF, which were last summed up by superspark in thread pam1209:
AS all the VSF 42mm sub releases, the following flaws are present....
Case shape, where the lugs meet the case
Case thickness
Cannon Pinion is too large
Fisheye crystal, unless they have fixed it?. Should be no lens effects on the new subs.
although. love the 47 and 44's the 42mm subs wear very well, just a shame they cant nail it. VSF have a policy it seems to stick the p9000 clone in everything where they would have been better served on the closed Caseback models using an eta clone. Then the thickness wouldn't be an issue for the case not the cannon pinion being too large.
In the same place, I gave some clarifications about the thickness, which are also better to see before buying:
https://forum.replica-watch.info/forum/panerai/9744502-vsf-pam-1209/page2
Otherwise, a good watch. And now the choice of 42mm subs is pretty big.
Reactions: centrum
