I wore the VSF SM300 Today and Every time I put it on, the not at 12 triangle kills me. I went to work, got off, and went to bed, and that was when I was like fuck it all, I dont care if I fuck it up, I cant allow this to continue! SO in my underpants, I went to the table, took out my old swiss army knife and started prying away at the bezel... I was completely convinced I was gonna royally fuck it up, then BEHOLD! it started to work so I started taking pictures....
I took the little blade of my SWISS army knife that I use to open casebacks with, and inserted it between the bezel and the case. I press down, then I pressed it in the other side, then the other side and the bezel became more loose each time, and then it popped right off.
As you can see, the triangle is so far off it would drive a man to murder.
Here are a series of photos showing my knife did not fuck up the case or the bezel
Moving along.
I then wondered how to get the bezel out.. So I noticed the back ceramic edge and steel edge and decided to use the big sharp knife of the swiss army knife and slid it in between, I worked my way around the whole thing and noticed the bezel started to move outwards.
After the bezel is out, I noticed there was a layer of sticky something on it, seeing this means for me that I will only try this once or else risk the sticky getting ruined. Because I dont have additional sticky stuff available if I ruin it, I would have to get rid of all the old sticky and put new sticky and that would be a pain. Plus the insert was rather thick and fitted in snuggly, so I figure I can reuse the sticky this one time, well not like I have a choice anyway...
So I try my best to align the triangle to the beveling, I am doing this because I know that before I removed the bezel, the bevel itself was pretty on point.
I made sure the click spring thing was positioned properly with the thing in the hole.. (also made sure the many angle wire inside the bezel was okay too..
then I prepared to give it all hell to push it back on.. but it went on with a small push and a click! So there you have it, I tried my best. Is it perfect? no, but hey, its close enough and I am satisfied enough that I can go to bed.
Thanks for looking,
Disclaimer: This is not a tutorial, This is just a post about what I did... and if you try anything, it is at your own risk, you cut your hand open or bust your rep or whatever, not my fault.
Moving along.
Thanks for looking,
