OK - I'm going nuts here. I'm not a beginner watchmaker, but I'm also not a pro. I recently got this Omega 300m NTTD rep VSF and love it. I wanted to pressure test the housing - which I did successfully to 150m (that's a story for another day) - but what I could not do is figure out how to remove the movement case ring. It might have a screw on the dial side, but I can't get the dial off because the levers that hold the dial feet in the movement are blocked by the case ring. Any ideas on how to separate the case ring from the movement?
Second question - what movement is this? What kind of crappy movement has the spring barrel exposed?
