VSF 8900 repair. Worth it?
Stratos858
Hello.
I own a VSF Omega seamaster 8900. It is 4 years old. After a hit, it stoped working and I can clear see a gear dettached from movement.
I leave in Greece. Is it worth to send it for repair?
Who I have to contact for?
mclarendude
31,137
39,628
ATL
I can't recommend someone but I am not too certain that you'd be able to source parts for it.
mclarendude
31,137
39,628
ATL
The thing you see detached is not a wheel, it is a cover for the rotor screw.
Reactions: RepsAllDay
Stratos858
Thank you for your reply and really sorry for the wrong forum post. Yes you are right, it is not a gear. However mevement does not work.
I was thinking to send it back to VSF. On local technician was unable to repair it.
You think worth it?
mclarendude
31,137
39,628
ATL
You think worth it?
I do not recommend sending the watch back to VSF/China. The risks of it getting lost or seized are too high.
I would check our Trusted Watchmakers section and see if any of them in the EU would take a look at it.
I would not be surprised if there is something stuck in the gear train. Happens often.
Reactions: Stratos858
Stratos858
Thank you. I will do what you suggest.
bavarex
Omega collector/watchmaking
3/4/21
135
150
EU / CAN
There are no real spareparts available and a lot parts are customized. The movement itself is not that easy to service as it has some flying springs inside for example. So you either give it to an experienced watchmaker or sell it as a sparepart watch. There are for sure people who are desperate for them.
Reactions: Horace_Derwent
dpd3672
1,935
3,232
Marv has a CNY Sale on these that would probably get you a new one cheaper than having the old one repaired.
Bonus would be that you now have a great source of spare parts should something happen to the new one, lol.
That said, it's hard to tell from the photos, but is that loose part just the decorative cover for the rotor screw? It could be glued back, or simply removed, and the watch might start working again, if it's causing the watch to sieze up. Will it run if you manually wind it with the crown? It's possible that it fell off when the watch was dropped, wedged itself between the rotor and case, and once the mainspring ran down, the rotor isn't recharging it.
This is the piece that looks to be loose, it's purely decorative, and the watch will run without it.
nissanskylinen1
60
17
Does anyone know any movements that would be able to just drop in the case and get things running?
Tschacko
485
185
These things usually run with A2824 but It comes with a few adjustments here and there. Especially the height and construction of the seconds pinion is not standard. But with a little bit of mix and match you can get it running again.
nissanskylinen1
60
17
So I have a 2824 and noted that the movement diameter is too small for the case. It seems like the body of the movement is a 7750. I was wondering if a 7750 would just drop in.
nissanskylinen1
60
17
For some reason I can't find the edit message button, but I also noted that the date wheel doesn't fit a 2824 - its too big for the movement, and an original 2824 date wheel doesn't line up with the dial window.
Stratos858
VSF does not provide replacement movement. At least thru Chazing TIme. I suppose the best way is to get a new one VSF8900 and keep this as spare parts!
Stratos858
I couldn't find any watchmaker in Greece or EU that could repair it.
Stratos858
Can you introduce me Marv??? :)
Day Old
13/4/25
Were you able to repair this/swap the movement? Or did you just keep it as-is for spare parts? Curious how this went for you.
RepPossessed
100 watches in the uk 🤌🏼
Trusted Dealer
10/11/15
7,479
2,499
N. Ireland
It’s very possible that that part has touched the hairspring while rattling around inside.
