- 27/6/16
- 818
- 2,742
- 93
Currently only this pepsi modelThank you Steve and is VSF going to make all the GMT models?.
Hopefully this thread title meant "same INSERT as CLEAN"@KJ2020
@steve_theonewatches the 3186 VS watches had other, better, not genspec bezel action with no backplay other than clean. With 24 holes in bezel, clixksprings like submariner. Can you confirm its srill the case?
Cause he talked about versions, i thought it is meant the insert (colors). But lets hope and prayHopefully this thread title meant "same INSERT as CLEAN"
@steve_theonewatches check out this thread below for some pics of the bezel construction VSF / GSF had on their 3186 models. The question here is if the VSF 3285 bezel construction is unchanged (still the Rollerball bezel) or if VSF now has the same less than stellar bezel construction like CLEAN.
A different type of rep GMT bezel - The Rollerball!
Different inserts by the looks.Thanks @steve_theonewatches Whats the difference in V2 or V3?
