VR3235 / SH3235 for DateJust 36mm ?
Specked
Rolex fanboy
259
60
Finland
Hello guys, was looking for a replacement movement for my VSF DJ36mm. Initially was looking at Aliexpress, found some, but they were all for DJ41mm. Does anyone know where to get a movement for 36mm ?
asusundevils1971
23,860
41,018
In Your Head
The VR3235, SH3235 and VS3235 movement are used for both the 126XXX 36mm and 41mm case. I would replace your VSF DJ 36 movement with the VS3235. They are a little more pricey but they are a better movement.
Specked
Rolex fanboy
259
60
Finland
I couldn't find those movements (VR3235, SH3235) in Aliexpress for 36mm 126200 / 126234, just for 41mm. Also asked some TD's for VS3235, but no one usually sells and the one who sells are requesting about 200 + delivery and latency of months. So not sure if it is worth getting a VS movement.
asusundevils1971
23,860
41,018
In Your Head
The gen date disc / wheel will fit the VR / SH 3235 movement. So you are good to go once you get the movement in hand.
Specked
Rolex fanboy
259
60
Finland
So for example here is the 3235 for the DJ41 and you can see that the datewheel is larger than for 36mm, will it still be fine to put on 36mm if I replace the datewheel ?
Reactions: Inilosiret
