I decided to give this project one more go... I would say after several attempts, the results have been unsatisfactory. I ended up buying the gen article.
This time round, I manage to secure a case from the closed down factory (thanks to triplehd, to part with such precious parts). However, it is still incomplete.
This what I have at the moment:
1. Case + caseback without bezel. Correct He valve placement and seems to have correct dimension too.
2. Crystal. No glass bottle effect!
3. No crown.
4. Movement retainer ring without dust cover.
5. Genuine Omega SMP full size white gold bezel.
6. Genuine Omega SMP 007 Bond dial, need some restoration on the lume.
This is what I am going to do:
1. Order genuine crown and tube.
2. Order genuine hand sets.
3. Attach the bezel to the case (this has a few challenges).
4. Try to find the dust cover (I am sure I have this but not with me at the moment).
5. Buy an ETA2824 stem as well as caseback gasket.
Since this will be a fantasy model (no 007 comes with white gold bezel... at the moment), I have decided to get a sword hand (like on those America's Cup version) instead of a normal SMP hand (with hole in the middle and minimal lume).
Current problem is with attaching genuine bezel to this case. It seems that the dimension is very good/precise but the construction is slightly different. The bezel spring is held by a nylon gasket on this replica! This nylon gasket needs to be glued to the case in order to secure it. Another problem is the crystal is not properly pressed. I will fix all this after I got the complete parts (i.e.: gen crown and crown tube). Stay tune!
3. No crown.
