Does the SS bracelet on the ultimate BCE use pins or screws? I searched all the pics I can find here and on dealer sites and I just can't tell. Thanks!
Screws....if I remember correctly it's the typical Breitling whereby you nweed to undo 2 screws and remove a link with two posts....I had a hard time with mine and ended up destroying one of the links to get it out.
here with the above mentioned watch on the arm (diamond bez,best rep going)..screws....this question comes up alot about watches though and all watches i own are screws,is there others out there?...
Well... I think most Rolex bracelet uses screw as well... and many other brands. However, I would recommend you to try IWC's pin method. It's very innovative and convenient when adjusting bracelet length.
