Well, It just arrived today! First impression is: WHOOO! That is huge!
So before I talk to you about this chunk of heavy metal, here are some shot I took tonight.
Now here is my small review after owning it for 4 hours
-Case: Very well finished, although many dealers are advertising it as Titanium, it is not! This watch is made of steel and is very heavy. The back cover is comfortable.
-Dial: Color seems to be spot on if I compare to the OEM website. The markers are well aligned and well defined. No lume on this watch and no date.
-Hands: Nothing to complain other than No Lume.
-Crown: The shaft that deploys to act as a crown is very well made and feels good. It has a spring and a ball that will maintain it in straight position when adjusting the time. The retainer mechanism that holds the Shaft when not adjusting the watch is very cheap. Lots of side play and you can feel the spring rubbing the case when depressing it.
-Bezel: Big disappointment there. The locking lever feels nice and solid, but when released, the bezel is very loose and rattles on the watch and even has side play. Sounds cheap. I believe if I could put a seal between the bezel and the case that would resolve the issue.
-Movement: Another disappointment, this watch is advertised everywhere as being equipped with a manual wind movement and even some dealers will say it is equipped with a A6497. Well guess what, the watch was already running when I unpacked it. And I can easily ear the rotor spinning when shaking it. Must be a 21j @ 21,600bph. Ill open it later to take some shots.
-Bracelet: All Reps I have seen are equipped with leather imitation bracelets. This one is no exception. But even though it is very thick, it is also very flexible.
-Buckle: Very well made, big, heavy, solid... just like the rest of the watch.
Overall, This is the most accurate U-42 rep out there as per my research and I am very satisfied with my purchase. I will wear this watch more often than anticipated (I was a bit scared of its size).
Do you guys think it is too big for my 7.25 inch wrist?
