Tudor ranger V6F Brocken Rotor screw
Transylvanier
Hello everybody,
today ive noticed a metalic noise from my beloved Ranger.
Opened caseback and found loose rotor screw. Try to fix the screw but it looks like broken.
Thonking about to change the movement to ETA. But not sure if it will fit.
Hugop
1,687
62
I think they are ETA 2824 sized. Would be perfect to change to a Swiss ETA!
Sent from my SM-G920P using Tapatalk
Transylvanier
Thanks for the information. Wrote to an lokal watch Smith he will swap the movement for 220€ to original Eta 2824 or repair an service my one for 130€.
Can't decide yet what do to?
Sent from the RWI mobile app
Hugop
1,687
62
Definitely ETA
Dr.Verylong
10,405
12
Given the cost I'd take the ETA. Just make sure that the Asian hands fit.
mui.richard
709
295
Definitely ETA. While you're at that see if you can get an elabore grade movement in it. It's a bit more money but VERY accurate out of the box.
I swapped an elabore grade movement into my TC Sub V6 and it's been running average +2 sec a day since, can't be happier with it.
And did your watchmaker mention if the new movement will have H2 or H4 CP height? I think maybe an H4 would be more gen like.
a watch is meant to be worn
Transylvanier
I'm so happy. Chris did a perfect job
Gesendet von meinem S3 mit Tapatalk
