Thanks! Actually I found bigger sizes from 30.5 to 36.5 mm on Aliexpress. They are described to fit with bigger Tudor. My issue is to understand which should be the corret on. Measuring the back open, the diameter between teeth seems 33.3 mm, thus I suppose a dye 33.5 mm should be suitable. But I'm not an expert and I'm trying to find some further information.
Inviato dal mio LLD-L31 utilizzando Tapatalk
