Tudor pelagos bezel removal
breitling87
111
31
Hi guys can anyone give me some step by step instructions with pics on how to remove and reinstall the Xf factory Tudor pelagos bezel ?
breitling87
111
31
I’ve searched and read that the rep pelagos bezel goes on different to gen. I’ve found some threads before with pics on rwi but can’t find any now. Have taken the bezel off but can’t get it back on!
DetektivTudor
The rep addict formerly known as Elfriede
918
264
Heart of Europe
Could you post some pics? Meister Hora removed the bezel on one of mine (V3) and strechted the springs to tighten the bezel.
Worked fine, but maybe there are different bezel assemblies? Is it a miyota v3/v4 or an older v1/v2 with a2824?
breitling87
111
31
has anyone figured out how to remove/replace the bezels on these yet? found this watch in my draw still with the bezel off how many years later..
Replisimio
1,131
1,122
Gods own country! Yorkshire.
No it’s the same as gen. I have a gen bezel on my XF and it fits just the same as a Rolex bezel with a hytrel ring buddy. Mine is the eta V5 version but I’m sure the others are the same. I’ll hav3 a look and see if I took any pics when it was in bits.
breitling87
111
31
Ah that would be great. I think my issue is I’ve lost the spacer ring if there is one. All I’ve got is the white gasket sitting in the ring
Replisimio
1,131
1,122
That should be all you need. All I could find was this showing the ring. The bezel fits direct to the case on mine. Maybe you need to show some pics for me to see what might be wrong. The white ring does sometimes need to be the correct way up to snap in correctly though.
Replisimio
1,131
1,122
