Tudor gasket replacement?
EDSON
96
Hello,
I bought a TUDOR ZF PELAGOS and the bezel was kind of loose, so I took it to my watchsmith and he removed the bezel and showed me that the main reason the bezel was loose is due to a broken gasket. I have written to the TD in order to find a possible solution and no answer back yet, so In case he does not respond with a possible solution I am considering to get a generic gasket replacement.
Is there any place where I can get a generic gasket replacement for TUDOR ZF PELAGOS?
Thanks in advance.-
kkgkkg
191
I couldn't tell you - I didn't have to replace mine, just reseat it - so hadn't bothered measuring. Can you not pop it off and measure the old one?
