Tudor 7016 replica build
shelbycobra
12/7/17
i want to buy a Tudor 7016 replica and add some vintage wear to it.
From What web site should i buy a good start from?
Thanks for your help this will be my first watch i modifie.
shelbycobra
12/7/17
I see all the time here people write about different case and more.
Is the one i posted a good case to start with?
I also nead some tool kit What would you guys recomend?
idontgrillonwed
111
You haven't really given us a lot to work with here. Use the search bar and start reading. There is a wonderful thread on "Budget Building" Tudors in the Tudor section of this site. It literally has recipes for accurate builds at different price points. Ditto for basic tools/watch modifications.
Study the reference information, learn about it, and decide what details are important to you. I love starting with the for sale section of The Rolex Forums, or Bulangs, or other similar site that has a ton of photos from all angles. Finally, set a budget. How much do you want to spend? Are you going to use gen parts? These builds can range from $350 for the JK or Cartel to $2000+ for Phong-based builds.
Good luck.
shelbycobra
12/7/17
Good luck.
Thanks for your reply
I like the look of the 7016 i send link from but i dont know what to look for if it is someting really bad about it? That is not even close to a gen 7016.
My thinking was to buy it and blech the insert and make some wear marks on the case and bracelet.
Are there some up grade parts i should buy you guys think to make it better but still a budget replica
