TTF 1314 - Review (heavy pic load)
JayBee0815
Repoholics Anonymous
10,213
33,927
Heart of Europe
Dear RWI Members. As we all know, this year was not a good year for us Paneristi. Since the raids, only a few new rep models came on the market and those that came were mostly of middling quality at best. So I was hopeful when I learned here via RWI that a new factory called TTF had released the 1312 and 1314 models. The 1314 was on my wish list anyway, so I ordered a copy from Tony (Asian7750) right away and let dear colleagues ALE7575 and KOT1917 talk me into writing a review. However, this review can only be a kind of presentation of the watch, since important conditions are missing - I have never had the Gen in my hands and unfortunately also no suitable comparison model such as the VSF 1314. In addition, I am of course not such an ace as the both named members , whose reviews are for me the ultimate. Nevertheless, I would like to present this beautiful watch to you, because it deserves it imo. The given scores are quite subjective. You are invited to discuss the issues and point on flaws, that my noob-eye hasnt seen.
Case, crown and crown guard
The TTF 1314 comes in the newer Luminor 1950 case. This case is comparatively slim and stands out from the design by the combination of the classic cushion shape and curves on the sides. While the Gen is stated to be 15.65mm thick, the TTF comes in at a smooth 16mm measured from the bottom to the topmost point of the crystal. Like the Gen, the bezel is polished, while the rest of the case is brushed. The brushing and finish are solid throughout, though the finish on the curvy edges doesn't quite match VSF's build quality. Here, I used a VSF 1056 for comparison.
The lugs are also neatly finished. However, the big weakness of the TTF is already noticeable here at first glance. While the Gen and the VSF versions of this type have the Panerai quick-change system, this is not present on the TTF. Instead, a classic change system with screws is installed. More about this later. On the case, this is noticeable in the larger holes on the crown side.
Both the crown guard and lever as well as the crown itself are very well made, at least for my not particularly trained eyes, and I don't see any major differences to the Gen or the VSF. Only the pin on the back of the crown guard protrudes a bit more than the VSF. But that is rather a minor thing.
The case back cover also makes a decent impression, although the quality of the engravings doesn't quite match VSF.
In general, the case is surprisingly well-made and hardly has to hide from the VSF.
9/10
Movement
The Gen features Panerai's P.9010 caliber, and the VSF version comes with an in-house clone of the P.9001, which VSF says is decorated to P.9010. Of course, the TTF does not have that. Instead, a decorated A7750 is used under the hood. I'm not an expert for movements, so I can't say much about the details of the workmanship. However, for me as a layman, the decoration looks neat and since the 1314 has a steel caseback anyway, this item is not high on my personal priority list.
8/10
Dial and hands
Other than movement, the dial is a key factor on this model. After all, the 1314's appeal stems mainly from the fact that it is the only white 44m Luminor with a sandwich dial. The dial of the Gen is also slightly textured. However, you can only see this structure when you look at it from the side. It is therefore very difficult to evaluate the quality of the Rep without ever having had the Gen in hand. There are some pictures of the Gen on the web, but they often look like they were generated by a computer or taken in high-end studios with perfect lighting.
In any case, the TTF's dial is beautiful. How close it comes to the Gen, I leave open. In reviews, the white of the Gen is described as "snow-white". That does not apply to the TTF. Its white goes in the direction of very light cream white. I personally find it even more beautiful than the Gen ;-)
The same applies to the structure. Here, the dial of the TTF looks a bit like a woodchip wallpaper. Of course, these are very fine details, but in direct comparison to the Gen, it must be said that the structure of the TTF dial is a bit rougher.
Another minus point of the TTF is that the sandwich dial has less profile than that of the Gen. Indexes and numerals are clean and - unlike the other newcomer HWF - also cut out in the right size, but it lacks the depth of the sandwich of the Gen. The lume layer is well below the Dial, but not as deep on the Gen.
The print is accentuated and textured on the TTF and has comparable light effects to the Gen. Unfortunately, on my copy, the second "a" in "automatic" is a bit too thick. This is not noticeable from a bird's eye view, but when looking from the side, you can clearly see the error. A pity. Whether this is the case with all models or only with mine, I can't say.
The hands are very good clearly better than those of the VSF 1314 ... just because they are silver and not white.
8/10
Lume
In the reviews on the Gen, you can read that the gray lume for the 1314 was made especially for this model. This of course presents a certain hurdle for a rep. But here the TTF does well. In the normal state, the gray looks a shade too dark. In active state, the lume looks nice "poison green" and is perhaps a shade too yellow and too little green compared to the Gen. But that is complaining on a high level. Otherwise, the lume of the TTF can convince and also has the light structure like the Gen.
10/10
Date
At first glance, the numbers look a bit narrow, but that's the same with the Gen as well. The white finish is also no different from the Gen. Whether the DW is lower than on the Gen is impossible to say without having the Gen in my hands. At least I can't see any difference in the photos.
10/10
Strap and strap replacement
The included leather strap is not really junk but also nothing for the demands of a Paneristo. But that's the case with every Rep. Or? The biggest weakness of the TTF is the missing quick change system. The button for it is present but without any function. Instead, a normal screw change system is available. This works perfectly, but the screw head alone is a point where you can immediately recognize the rep as such. This weak point clouds the otherwise good to very good verdict.
4/10
Conclusion
The TTF is a good rep, and if it weren't for the lack of a quick-change system, it would almost come close to the good old VSF quality for these models - at least if you don't mind the 7750 movement.
In the good old days, the TTF would be a rep that would probably go down among the factually certainly better reps from Noob, HFac or VSF. But the good old days are over and with the TTF, at least for me, the hope grows that next year we will finally get Panerai reps that are worthwhile again. Therefore, my conclusion is also very positive. One should not forget that the 1312 and the 1314 are the first pieces of this factory. But the TTF 1314 is really very good. A small drawback is, however, that TTF sets a price of 368 US$, which is 20 US$ higher than the old VSF price. This is of course due to the bad times and compared to other reps the price is still moderate. Nevertheless, 368 US$ for a good but not extraordinary Pam-Rep with 7750 movement seems excessive to me.
So, we can be curious what TTF has in store for us. In any case, the premiere was a success.
Final score: 8/10
weathermanGTS
Load "*",8,1
2,754
14,530
EU | CH
really awesome review! Thanks!
and thanks to your information, I cancelled my order of the VSF 1314 with the white hands ;)
Reactions: JayBee0815
derjenigewelcher
Watch enthusiast
9,753
13,214
Switzerland
Thank you for the insight into the Panerai world. Even if, as an avowed Rolex fan, I should actually find a lot about Panerai historically, I only like the watches to a limited extent.
I find the photos, especially the close-ups of the dial, remarkable.
Thank you very much for bringing the watch (s) closer to you and for the effort you put into the forum - way to go!
Plaasbaas
IWC-hoarder and PAM-hunter
3,215
7,677
Very nice, great pictures and very detailed description. Extremely helpful for all Paneristis. Let's hope for more models, more manufacturers and better times in 2022!
Blshh
540
858
I got TTF 1314 qc yesterday, my case back was showing _0713/3900.it is totally wrong for the production amount but I accepted it because the 0713 is my eldest daughter birthday.
kilowattore
14,199
6,974
Excellent review Sir, featuring great pics and detailed text. We got an exact idea of the ins and outs of this rep.
Personally I agree with you that this release from this new factory is a sign of hope for the future. The strap changing system can be implemented quite easily and thus I think it shouldn't be a problem for future releases. The decorated 7750 movement is a false problem in this case and frankly I always found similar solutions acceptable also with display case back.
Nonetheless I hope TTF factory can get their hands on some clone movements for their next models with display CB.
JayBee0815
10,213
33,927
Heart of Europe
Thats strange, cause on my model they got it correct. Here is a picture of the Gen caseback ...
whitegold
196
440
Thoroughly enjoyed reading the review.
A big thank you for all the time and effort that went into it.
Positive signs and hope for better things to come since the closure of what was the ultimate best
Sent from my SM-G9910 using Tapatalk
KOT1917
3,396
5,548
Russian federation
Thank you for taking the time, effort, and giving this review, JayBee0815 !
Beautiful pictures!
As for the PAM1314 TTF themselves:
- The color of the dial and the lume, I also will not undertake to evaluate, you need a parallel comparison. The color of the disc can be influenced by the "warm" tone of photographs, or the specificity of color rendering, texture is a matter of detail and sharpness, and the color of the lume also largely depends on the width of the notches and the depth of the sandwich, which makes its beauty: color inconsistency at different angles and different lighting.
I can say one thing: after PAM1314, VSF gave PAM1394, which I liked much more in terms of its color scheme, and although it was not produced as GEN, 40mm PAM1271 was made, and I must admit, in terms of the dial it is very close to PAM1394 VSF.
So, PAM1314 TTF is, in my opinion, very close to PAM1394 VSF in terms of font color, lume and specificity of markers, and there is no way to compare it with GEN in parallel, it's easy to say that it's beautiful and pretty close.
- Polished hands are a victory, and this already puts this watch formally higher than VSF, at least in the absence of an actual error right on the dial.
- At the expense of DW depth - I see no problem. The font itself is thinner than we are used to seeing, but if you pay attention, GEN PAM1314 has a slightly different font than the models, the date of which is printed in light font on a dark wheel.
But anyway, I would like to see the date font a little more confident.
- To review the case, I would leave here a wonderful link that compares VSF PAM1312 (has the same case as PAM1314 VSF) with GEN:
https://forum.replica-watch.info/for...gen-comparison
Everyone can look at these comparison photos, and follow the link, go to gen, and form their opinion.
I believe that the case is made and processed noticeably worse than VSF. This can be seen almost everywhere.
The shape itself is correct for this model, the thickness is good, it's just that the case is cheaper, and you can see it.
- CG also assembled and finished in the spirit of the case, the profile shows the adjustment of the lever to the CG itself, there are no chamfers, they almost never existed in VSF with rare exceptions, but at the base of the CG, when joining the case, it was worth making small cutoffs.
The crown is thicker than VSF and GEN and is again poorly polished, the bevels on the teeth are also made only from the bottom.
I would like to note that the VSF PAM1056 crown, with which the comparison is made, done better the more often seen on VSF.
- As far as movt. Is concerned, I don't see a hard need for furniture to have a clone. It's not convenient for me to manage it, and solid caseback makes the appearance unimportant, especially since the 7750 + deco plate for the P.9010 style is clearly more similar to GEN than the P.9000 clone, especially since the CP is close in size (by the way, it seems to me, or is it not polished?)
- As for the caseback, it's just that the engraving is worse, and as I understand it, there is a certain number of watches with the wrong circulation of the year. It's just a little bit less qualitatively done than the VSF had.
- Separately, it is worth mentioning the quick change system. This is a funny flaw, if they never change it, it will be just ridiculous. There is nothing complicated here, a working system can be found at $ 150 dhgate.
I'm sure everyone, thanks to the OP's work, has an opinion on these PAM1314 TTFs.
I have it like this:
This is a beautiful watch overall, but this is not enough. They need to be precise in detail and high quality workmanship to compete in the major league reps.
So far, what I see looks more like improved XC models (aka KING), with DHGATE, in which they installed 7750, instead of ST2555, and a decent dial, compensating for the error of a large factory.
Good move? Of course, and I am grateful to them for that.
What's wrong with that? As has already been mentioned correctly - the price.
Not only the lack of a clone, but the overall quality of the geometry, finish, is what made the VSF 44mm 1950 PAMS so much like the GEN. Here this is not to the extent, and the price, at the same time, corresponds to the highest expectations from REP PANERAI.
My personal opinion is that it should be cheaper than the $ 100 - 150 VSF, and then everything falls into place, and there are no more questions about the shape of the lugs and the weak trim of the crown.
However, they have no one to compete with, they do what they can, and this is no longer a bad thing, but in no case, not on a par with the best.
I apologize for the verbosity, and thank you for the information provided for reflection in the form of a photo.
JayBee0815
10,213
33,927
Heart of Europe
Thanks KOT1917 for the expert addition, especially on the points where I could contribute little due to lack of detailed knowledge. It's just like I said in the OP - some things a noob's eye just can't see ;-)
Reactions: KOT1917
Casinoboy
1,223
816
Great review JayBee0815 thank you for this. Very detailed description. I love the structure of the dial!
Sent from my SM-G998B using Tapatalk
KOT1917
3,396
5,548
Russian federation
The main thing you did is write a review. This is valuable. Few of those who have relevant models for discussion do this.
Thank you!
mrsullivan
Pink Replicaddict
9,569
19,902
That's what a review should be like, thank you JayBee0815 . Great explanations, amazing pics with all the specific angles needed for a good insight. Accurate and deeper anaylisis from KOT1917 make this "team work thread" giving us a pretty complete overview of this new model.
TTF may jump into an "improved DHgate" market, I think everyone agrees that regarding the actual state of Pam rep market, it gives hope for enhanced versions of their production in the future.
We'll see how they go but this is a pretty decent try so far. Nice watch !
Envoyé de mon SM-G991B en utilisant Tapatalk
JayBee0815
10,213
33,927
Heart of Europe
You are right. When I look at a rep there are always two levels in my mind - the "professional level" (how close it is to gen Gen, how good is the workmanship, what are the techincal specs) and the "emotional level" (how does the watch looks and feel, what triggers me). Though the TTF 1314 surely has deficits on the professional level, it absolutely triggers my emotions. But that is of course a highly subjective matter ;-)
Reactions: mrsullivan
ALE7575
Section Mod
19,847
434
Thank you JayBee0815 for the effort and well done job on this good and illustrative review. Great pics are also appreciated.
Now, we all can have a much clearer idea regarding the quality of this TTF replica.
In the absence of the comparison with the GEN, it has been a very good idea to make the comparison with the current reference of the VSF rep.
I agree with practically all the good observations made in your detailed review. Only, and according to KOT1917 , I do not think that the caseset is comparable to that of the VSF (although the shape in general is quite accurate). It is not only a question of the lack of a real quick-release device, it is also the difference of finishing in all the details, from the polished to the brushed surfaces, the transition edges, the CG without chanfered edges, the adjustment of the CG joining the case, inaccurate crown ... well, there are many details of the TTF caseset that make it clearly inferior to that of VSF.
Anyway, TTF's is a good attempt and quite successful and the effort of TTF is appreciated, one of the best today.
Thanks again for the great work and I encourage you to maintain this great level of cooperation.
ALE
SampsonSD
68
32
South Dakota
Can't thank you guys enough for the countless hours of research and review. I so appreciate the work you gentlemen do. Much appreciated!
