Thoughts on 9015 movement
reppotato
81
42
Miyota 9015 is known to be a workhorse movement and easy to modify. Its widely used in many reps but I feel the winding efficiency is quite low, especially if you silence the annoying oscillating weight noise. What do you guys think about this movement?
mclarendude
31,647
41,265
ATL
Great movement. Miyota’s response to ETA’s 2824 and 2836. Only downside is that the rotors can get loud without proper lubrication.
reppotato
81
42
Personally, I find after the silencing, the watch will stop during the night as the winding efficiency goes down. Does it happen to yours too?
Plaasbaas
IWC-hoarder and PAM-hunter
3,288
7,950
This does not sound right. After proper lubrication with the correct oil for this task the rotor should rather spin easier and thus wind the watch at least as well as before.
Reactions: mclarendude
mclarendude
31,647
41,265
ATL
Agreed with ^
You could be using the incorrect lubricant. Something thicker.
Reactions: Geonor
Geonor
1,419
3,597
Norway
Agreed with ^
Yeah a lot of modders like to grease the rotor to silence it but what it really needs is a cleaning and a very very small amount of something like Moebius 9010. If you're using grease or thick oil and especially too much of it which is easier to do with thick oil or grease, it has a habit of seeping into the rest of the movement and causing havoc.
mclarendude
31,647
41,265
ATL
9010 does it for me. I wonder if even maybe one could use Lubeta.
Reactions: Geonor
reppotato
81
42
I see I see. Can I clean it off with soap or alcohol? Then use Moebius 9010 instead?
Geonor
1,419
3,597
Norway
Not sure, I clean my parts with an ultrasonic cleaner in a glass with elma clean, then a glass with distilled water and then with isopropanol.
Reactions: reppotato
