There is a noise coming from my newly received 2018 KOR Cartier Santos Large from PureTime
punksterz626
21
I just received my Cartier Santos from Puretime puretime and there is a noticeable noise coming from the watch when i move my wrist. It sounds as if something is loose inside. I'm not sure if thats normal or if it is a defect. I'm wondering if anyone is having this issue and if there is something I can do to fix this issue. Any suggestions are greatly appreciated.
thanks
Tucker
Lunnyfied by Raddave
18,020
10,542
thanks
It’s just the rotor on the automatic movement. Probably a Miyota 9015.
Kup55
57
19
You need to oil it or get it service..
Martycus
4,574
3,804
before you ask, search the forum on how how others have approached that with a DIY
chocolito
1,663
879
It is a Miyota 9015 movement. Is that normal? The sound is quite noticeable.
The Miyota 9015 has a one way rotor , it's winds the watch spring one way and spins freely the other . You don't need to service it ! You have two options the first which will make very little difference oil the central pin with a minuscule amount of mobius oil . Secondly change the actual rotor for a heavier one , much better however not too heavy as it effects the automatic winding and power reserve .
I would just get used to it , all Miyota 9015 are noisy as it spins freely , you won't notice it after a bit .
LedleyKing
37
London
Appreciate this response - as i was worried myself. Got a 3kf cartie santos from Trusty.
One more question, I left the watch on its side over night in a drawer and when I took it out the seconds hand was not moving but started moving after a minute or so?
LedleyKing
37
London
Yes, it is normal, Miyota rotors are known to be loud.
Also, I left the watch on its side over night in a drawer and when I took it out the seconds hand was not moving but started moving after a minute or so? Why is this?
Thank you
Plaasbaas
IWC-hoarder and PAM-hunter
3,146
7,369
Thank you
Did you ever wind it manually or did you rely on the automatic winding mechanism only?
chocolito
1,663
879
Sounds like the watch stopped because it ran out of power reserve as the mainspring wasn't fully wound . I suggest resetting the time on the watch , when you do handwind the watch gently 20 times clockwise ( UP) . They use genuine decorated Miyota's in these rep watches .That is about right to fully wind a 9015 . Then put the watch on your wrist , the noisy rotor and auto module will keep the watch wound . When you take it off , it should now be ticking when you wake in the morning . Finally don't leave the watch on it's side overnight . Theses watches are only tested in one position on a timergrapher when assembled ( if at all) .I would store the watch FLAT .I appreciate it's difficult with the stiff intergrated bracelet and clasp on a Santos . If you have a watch box sit on the/a cushion from the box when not using .
chocolito
1,663
879
I am experiencing the same spinning noise. is it dangerous to make abrupt movements with it then?
No , see above .Unless you mean by sudden movement , playing golf , or a set of tennis with Novak Djokovic ? This i wouldn't recommend with any automatic watch .
