TC Sub...I mean Rolex with custom case on ebay
Raddave
Administrator
67,017
18,605
Thats not a Yuki movement...its real....
velox
3,945
245
What do the experts say about the case etc. ?
cybee
11,134
30
Are the etched crowns on the crystal normally that easy to photograph?
KBH
7,168
42
Sure that's not a BK TWB case? He mentions solid mid link bracelet which is what BK's have. I personally wouldn't know the minute differences between the two.
944black
131
25
I have gen Xtal on TC LV and it's very difficult to photograph without a strong light source..... Could be OK though on this one, as can't be seen during normal face-on shots.....
Is this a gen dial then? Seems to have detailed raised print like my TC KH dial.
Datewheel also looks to have "raised" print...... Gen?
ItalianSub
337
The listing names everything as "custom" except the crystal. I assume that means the dial as well. Interested to see what the final value is...
KBH
7,168
42
As I said ealrier, I think it's a BK Taiwan case. Looks like it will probably go for over $3000. Way more than I would have thought it's worth.
I may have to start buying up old Datejusts and converting them to Subs.......
Ralphy
SalesMod CodeName Duchess
8,963
2,713
Nebraska
You mean "custom aftermarket" subs! :rollingonthefloor:
KBH
7,168
42
You mean "custome aftermarket" subs! :rollingonthefloor:
No. Mine would be "Real custom aftermarket Subs".
And I could put an ETA clone in the left over Datejust and sell it as a "Real custom aftermarket Datejust".
I'm seeing about a $2000 profit or more on each pair.
DVNE
3,467
108
BK TWB case has the correct stem height for a 3135? The serial engraving looks good to me. Man I suck at this game.
MSAMatt
1,760
wow.... just wow. I mean, decent strategy, but that's shady as hell.
DVNE
3,467
108
I thought not but hell, been wrong before :)
Heck, I didn't even know that the BK TWB had the indent inside the case to accept the 3135. Aside from the cg shape, I wouldn't have been able to tell. The engravings even has the short 'E'. RWI is such a great resource!
Bet the seller is a member here
silentflight
1,334
137
What do you fellas reckon the depth rating this watch could possibly attain?
I would imagine much less than an all genuine sub.
oldtools
582
580
He said his watchsmith tested it to 1000', same as gen. Also, the first generation TC subs came engraved between the lugs and on the rehaut. They even were engraved with a rolling serial number, so everybody's number was different. TC's original bracelet was also engraved on the endlinks. I'm pretty sure the case and bracelet are early TC. The rehaut engraving was removed, added a gen 3135, gen crystal, gen insert, gen box(?) and bingo $3100.
silentflight
1,334
137
Yeah. We have to keep in mind the movement alone was likely well over a grand. Another 600 between the crystal, box and insert.
