Anyone know if it is possible to remove a 4813 and replace it with an Eta 2824? I have a eta which has been serviced etc but the case it came out of us terrible. Wanted to get a PO from toro and swap movements
May require a movement spacer! I don't know if the crown position is the same though??
They will be some Omega guys chime in soon that can give you a better ideal. But I think the crown position is different. I think R2D4 went through this! He got a thread on it in the Omega section! Check it out!!
Dial feet you can fix if you shave them off and use dial dots but the biggest problem will be the hands. After all is said and done I would sell what you have and just upgrade
