Swan neck part FIX
Stepien100
Today i have read all this 3 part long thread about swan neck. The thread is absolutly great, but haven't seen anybody trying to fix that part. I'm just thinking if you can unscrew swan neck, then make it more plastic by worming and gently give it correct shape shouldent it work?? Or problem sits in material which is to fragile or stiff.
I understand also whole mechanism would only work with correct length screw.
ALE7575
Section Mod
19,847
433
Hi Stepien
Thanks to have the patience to read ALL my Swan Neck threads !!! :facepalm:
Of course you can unscrew the Swan Neck spring, but you will obtain nothing with any treatment. The material will not be appropriate and in case you had a correct spring the treatment it is not easy.
Leave your watch in this way and enjoy it!!
You could just try a cosmetical adjustement if you have an incorrect Swan Neck position !!
In my PAM 111 Noob the Swan neck is like this LOL LOL :facepalm::facepalm:
Look at the short screw and the tip of the screw doesn-t touch the regulator lever !!!
ShiroTenshi
6,805
258
Always wondered why is it so hard to use a 1mm longer screw lol
chromed.
2,460
the part is available, u just need to know the part number.. i believe there're a couple of threads providing info on this part.. goin's the only person i remember providing this mod, should u need to send it off to a modder..
