SW200 with loose rotor
watchstreebets
4/9/24
I have a V7F Navitimer with an SW200 movement but the rotor seems to be loose and makes the entire watch sound like a cheap toy when it moves. The rotor is like a micro-seasaw when I press on one side and the other.
I opened up the back, lubed the bearings, and tried to screw the center screw tighter, but it didn't seem to help. It's possible my screwdriver was too big, but hard to tell. Any thoughts?
watchstreebets
4/9/24
I assume the factory/TD swapped the selita rotor for the decorated one and it either doesn't fit right, is bent, or is just loose.
