Just looking at the differences between the SA 1 and SA 2, i havent yet owned a gen SA 2 or handled one but i have picked up a pro 3 bracelet which i was going to use on one of my other SA 1 watches, this is where i found some slight differences to case so im going to try to do a little thread to show these differences.
HERES THE SPECS.
Specifications
Gallery
Specifications
Gallery
Complications
Chronograph, Date
CASE DIFFERENCES
Red dots
pointing out that this is where the case has been trimmed out right back into case a bit like the planet ocean now so that many of the future straps will be shaped around this area or you will have a void between case and strap, i have seen a limited edition SA2 with a new kevlar strap that is shaped into these lugs which looks pretty great.
Green (bezel)
Pretty obvious really but the font has changed some how reminds me of the A-team logo from the 80s not sure why but..........
Blue (inner bezel or flute?)
the ring inside the bezel this is complete and solid unlike the old version where it had cut outs at every hour mark to help allign the bezel, this is part of the case and not the bezel.
Case in general
the case on the SA 2 is slightly thinner
just popping out for lunch so ill get back to it add more pics tidy it up a bit etc and do a difference between the pro 1 2 and 3 straps.
HERES THE SPECS.
Specifications
Model: | Super Avenger II |
Production Years: | 2013-Current |
Gender: | Mens |
Case Materials Available: | Steel |
Movement: | Breitling 13 |
Power Reserve: | 42 Hours |
Water Resistance: | 300m |
Bezel: | Unidirectional |
Crown: | Screwdown |
Crystal: | Sapphire |
Diameter: | 48mm |
Thickness: | 14.5mm |
Weight: | N/A |
Bracelet: | Professional III |
Lug Width: | 24mm |
Watchwinder Direction: | Both |
Reference Numbers: | a13371 |
Gallery
Specifications
Model: | Super Avenger |
Production Years: | 2004-2013 |
Gender: | Mens |
Crown: | Screw-Locked |
Diameter: | 48.4mm |
Thickness: | 18.6mm |
Weight: | 153.30g |
Bracelet: | Professional II |
Lug Width: | 24mm |
Watchwinder Direction: | Clockwise |
Reference Numbers: | a13370 |
Gallery
Complications
Chronograph, Date
CASE DIFFERENCES
Red dots
Green (bezel)
Case in general
