just received my 183H over a month ago. When I first put on the provided strap I realized it was difficult for one of the screws to engage with the case. I did get it in, but probably took an hour (not exaggerating), while the other three is literally ~2 minutes. I do realize there is a channel in each of the ends that the screw is suppose to anchor into, but one hole is giving me a really hard time.
I just received a new strap (from tootall: thanks!) however again I am having issues with this screw/case. I truly believe it is the case, and not the screw as the threads on the screw look the same as other 3. Should I try to send back to Davidsen? Is it worth this trouble? or should I try some type of loctite? which version of loctite (220?) Is this issue common/par for the course for reps? Suggestions?
Davidsen sent me some screws, but they were longer and shaped differently (these were fully threaded, whereas the original ones had no thread near the top 1/3 of the screw, clearly different and they didn't seem to work. I didn't want to try to hard with these other screws.
