Strap problem.....
the_don_robinson
325
Hi all,
I bought an AWESOME soft strap from one of the spanish strap makers. Very happy with how it looks and the quality of the leather but....
... i cant seem to get it to 'fit' on to any of my 44mm Luminor cases. It is the correct width but i think its too thick. I uploaded some pics at the below as i wasnt sure how to insert them here dynamically.
http://s1170.photobucket.com/albums/r531/the_don_robinson/
anyway as you can see in the photos the hole where the tubes go isnt very tight and the strap cant rotate the 180 degrees so is constantly in one position, otherwise it feels like i am putting strain on the tubes.... Its difficult to explain but hopefully the pics make it a bit clearer.
anyways im not sending it back (i have had it ages! just never got round to sorting).
Is there a good way to 'fix' this ?
Is it just too thick?
Any help appreciated as it is a nice looking strap!:cry:
Cheers.
Adam
Never
gianton
1,060
62
Greece
From what I see the strap is too thick in the lugs. There's not much you can do really. Try mounting it with no tubes. Only the maker can fix it but I think it's too much time to do that.
justlounging
2,725
100
That looks like a gunny strap and yes it does look a tad too thick..perhaps you might like to lightly sand the strap down a little..
other than that, just keep wearing it? the leather should be supple enough to accommodate the lug screws..
the_don_robinson
325
thanks guys.... whats the best place to shave it down? somehow on the inside or the outside/ underneath? regular sandpaper?
sorry not worked with leathers before! cheers.
justlounging
2,725
100
hmm i would say at the spot where the strap touches the case..having said that, you need to be aware of what you're doing..you cant put back what you shaved off..
best to check with the strap dealer on this..
allez
343
133
in German speaking area of EU
got that prob also with a handmade strap...i did it with a little round file and skimmed leather from the inside. on the outside you will see it...i would try it inside...
is it a jose maria (CB straps)???
maybe your PAM isn´t a "super rep so it doesn´t got perfekt meassurements at the lugs! Do not recognize the model from the side...
Got that prob with a cheaper PAM rep, with my ultimate 177 Hfact no prob...sometimes just half a milimeter helps :/
frigpig
Ghost of Sales Mod Past
7,845
77
This is the best solution but I use a drill and a drill bit the same size as my tubes.
Put it in all the way, start your drill and move it back and forth while pulling down on the strap. You have to be carfull to keep both sides even, so move the drill to the other side of the strap then back.
I've done this many times with many straps. I love my 6mils. ;)
ALE7575
Section Mod
19,846
422
I agree with this frigpig's solution
I guess he is means like as follows
ALE
ALE7575
Section Mod
19,846
422
good idea guys, nice demonstration ALE! :D
I was a little afraid - got same idea but for me the file was better I think...not a mechanic, just a pencil pusher :D
You can use the circular file instead of the drill no problem.
ALE
justlounging
2,725
100
That should be kept in the new 'Strap' section if you're planning to create ALE.. :)
PolonusTM
2,121
706
Since it is a "drawing day" ;) Sunday morning, having plenty of time and it is me very fond of fat straps - the problem is known.
My solution instead of filing the hole was to compress just the edge of hole using vice, pieces of hard wood and a nail. Filling always left me with a bit too big hole which I disliked so I "developed" this approach.
Benefits:
- no extra space appears, nothing to be filled with anything
- no material removal = no compromise on strap durability
I hope the drawing is self-explanatory ;) Just remember to remove tubes before this operation since you don't want them to get damage. Clamp it in vise and give it a couple of minutes to acquire new shape.
micscave
51
Benefits:
That's a brilliant solution which I might need. I've got a 6mm - 7mm gunny strap incoming and was a bit worried about it being a little too bulky.
Good job mate.
the_don_robinson
325
Excellent suggestions guys!
I love this strap and will def try the drill solution (i dont have a vice handy)!
It is a Jose strap, lovely and soft, great colour.
The watch it is on in the photos is a Getat MM homage but the problem is the same on my 111n and 112. Reason i stuck him on this is i didnt want to squeeze or force the screws in case they misthread....
thanks again folks will get em fixed up and post a photo if it works! Cheers
frigpig
7,845
77
You can always ask the strap maker to skiff the area before he glues the strap next time too. ;)
ALE7575
Section Mod
19,846
422
Benefits:
Hi Polonus
Thanks
this is a CLEVER and sure and reliable solution
Highly recommended
Thanks for the magnificent drawn.
The PCTeam is working !! LOL
ALE
Did you draw this Ale? You've got waaaay too much time on your hands! Nice job. ;)
The idea and the merit are yours frig
The draw gets just ten minutes in Photoshop!!
Thanks for share the idea
As said above:
The PCTeam is working !!!
Thanks again
ALE
mysterio
9,794
866
This is one of those instances you need to tap strapmakers, hence the need for seats in the PCT. ;) For example, won't the leather spring back to its regular thickness even after being clamped in a vise? Will this work for all types of leather, given their varied properties?
ALE7575
Section Mod
19,846
422
As you have surely read in the Thread for the TEAM introduction, we are considering seripusly the creation of a Sratp staff in the Team
We will see
ALE
