Strap help...
pwrslider
518
Quick question....
I just downloaded a MM ruler from the web 1:1.... and measured the SS bracelet currently on my LV. As far as I can tell.........its 180mm. I've seen a bunch of straps for Pams at 130...but none for 180...
am I doing this wrong..??
tootall
Vendor (Strap Maker)
2/5/06
1,343
pwrslider said:
Quick question....
Nope you aren't doing it wrong. If you were to measure from the hole of the Pam strap to the case and then from the buckle tang to the case and add them you would have around the same 180mm measurement.
On a Pam strap there is overhang on the longer strap side and also room to allow you take the strap on and off. With a SS strap, it's doesn't need this.
What are you trying to decide? Maybe I can help :)
