Strap and buckle incompatibility
nehnehchui
202
Hello all,
just received a 24/24 strap from bob and while trying to use a buckle from a previous 24/24 strap, i realize that there is plenty of tension when sliding the strap through the buckle.
Anyone has this issue with their buckle and strap?
mysterio
9,794
866
The strap from BOB might be just a tad wider than 24mm, hence the difficulty in sliding the strap through. Or you have a deployant buckle and the one from BOB is not designed for a deployant but a tang buckle.
nehnehchui
202
ah that explains it,
using a normal tang buckle. im afraid that after a couple of sliding, the leather on the strap might get worn out faster than it should.
**edit
using a pre-v buckle. is there the difference?
