Sounds like your rotor or your rotor bearing is causing that noise. Remove your rotor and check inside the sides for signs of rubbing. Also check your rotor bearing with a strong loupe. Have heard that same sound before but on an ETA mvt. That one was used by the owner while playing basketball. Go figure. Hope you find the cause.....Best regards
