- 12/6/09
- 68
- 3
- 0
Hi Watch experts!
I've got a problem with the Seagull ST1901, the chronograph hammer not resetting properly. There seem to be some friction preventing the hammer from slamming home tight.
Here is a video: when pressed the reset pusher the hammer struggles to slam back to zero position, I have to use a tweezer to push it back in place.
I've check the hammer spring, nothing is warped and the tension seems tight. I've even oiled the hammer pivots.
The hammer tension spring, looks to be fine.
The hammer pivot was oiled.
Do any of you experts know what may be to be the problem and where I could look into?
Thanks a lot in advance.
#st19 #seagull # venus175
