Hi, I have just received a Speedmaster day date and the bracelet is causing problems the clasp is really difficult to open, the side buttons press but the stud is not released, i think the stud and hole are mis-aligned, has any one experienced this and cured it or should i just return it for a replacement?
Also has any one used a leather strap with a speedmaster day date, if so where did you get the strap and rep buckle ? I measure the lugs at 19mm which seems odd, all references I see suggest thsi is a 18mm lug size?
I will post pics soon, xmas shopping got in the way of photography !
tangle
tangle
