So, which movement is my Ultimate Light?
caravaggio
1,248
OK experts out there!! :wink:
here are the photos of the movement inside my Ultimate Planet Ocean from Andrew.
What do oyu guys think??
takashi
11,500
Something called DG2813... Basically it's Asian with hi beat rate.
caravaggio
1,248
So, should I feel that I got screwed with that infamous "Little White Lie" from Andrew?
Since this is NOT an ETA copy, can this be serviced or easily replaced later?
digitalgulby
90
So is this was the ETA asia copy looks like inside my 45mm PO?
If so, I am pleased as punch!
If not, does anyone have a pic of what the inside of the PO asia ETA looks like?
takashi
11,500
This is so called Asian copy ETA coined by themselves. However, it is not a copy of 2824 or 2846 like you can find in River's Sub or newer batch of VIP mariner. You can determine it by the look of balance wheel, regulator, rotor ball bearing.
cybee
11,134
30
My GMT and Omega 007 from WBK have that same movement...it's got that little insignia under the balance
that some Asians have...both of mine are running strong....you mean it was advertised as ETA?
crumpdaddy
1,716
This again shows me that I need to just stick with straight up ETA's - if it doesn't have the ETA stamp, I'm stiff-arming like Walter Payton....
andreww
2,249
Yes, it is a "little white lie". I knew in advance what was inside as Josh has a movement pic posted...
Great watch for the price, but there is no need to try and pass this off as anything related to ETA.
tourby
125
looks like a asian miyota movement
a copy movement should looks like the genuine... but this don´t look like a ETA--- why it called ETA copy??
watchman12345
1,630
The first batch of these PO lites had the real Clone of the ETA 2824, almost indistinguishable from the real thing as testifies by Ziggy himself. Look at Rivers $99 sub to see the movement.
andreww
2,249
I think you are mistaken. I bought the early one and a recent one. Both, and as far as I know, all have had the cheap asian movement.
