Snowflake build from a while ago
Bonesey
8,926
66
Did this a little while ago but forgot to post up the pictures.
Cartel 5512
Yuki dial / hands
Yuki pearl
Gen low beat 2846 (serviced)
Gen 703 crown / tube
JMB Caseback
Usual cosmetic work. Some interesting points about this build. The cartel 5512s seem to come without engravings now. No model or serial numbers between the lugs. The Clark T19 / Sternkreuz dome T19 both make the rehaut look really bad. The bevel service crystal from Sternkreuz is much better and can be re-shaped if needed for smooth edges.
tt88
㊙️ Time does not wait ㊙️
12,502
6,757
Village, of course
Lovely build bonesy!
Wonder when I'll start having one of these snowflake...
:drool:
Sent from my Bezel using a 116610
Bonesey
8,926
66
I was pretty happy with how this one turned out. If I had to do it again I would have replaced the hour wheel and canon pinion with a higher set. I couldn't match the pearl lume with the dial lume with the powder that I had so I took a set of Phong hands that I had and removed the lume and ground it up for re-use. I've not found a proper way to re-create that orange colour with the stuff I have.
paulc1
85
Very nice indeed a lovely piece and fast becoming my fave.
federico
513
very nice, but I wish those CG were longer and the crown position wasn't too low
Bonesey
8,926
66
Yeah, unfortunately a flaw difficult to change. You can do some more serious work on the case to reduce how far out the crown sits, but the height you can do nothing about.
txrob779
7,604
14
Looks great....I blame you for my Snowflake affliction SIR :p
Dukes
549
51
Great watch. This makes me need a Snowflake,
Soxxgo2
759
81
Phoenix, AZ
So did you ultimately keep the sternkreuz service crystal? I have a stock cartel case with a snowflake insert and the crystal magnifies like crazy. I like the dome look but it's a little annoying. Also, it scratches soooo easy.
