I want to get my SMP bezel to look the proper way, so I'll have to try to align it myself. As far as I've read things here, there are two ways that are propagated:
1) Use a heat source (sun / lamp) to get the glue between the bezel and the insert to loosen and turn the insert into right position.
2) Get the entire bezel off by applying some precise blunt force, then get the insert out of the bezel the same way. Then re-glue the insert back the proper way. Put bezel back on the watch.
As far as I'm concerned, number 1 seems a lot easier, so I think I'm trying that first. But before I attempt this technical feat, I ask you, my fellow replica connoisseur gentlemen:
- Have you done / tried this on your SMP (or similar watch)?
- Has anyone tried it and have things go wrong (like the watch getting damaged / parts melting or something exploding in your face or burning down your house and such?)
Thanks to all who share their experience! (wow, this last sentence sounds like it came out of some chick pregnancy group :roll![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
