Slightly misaligned dial PAM 114 H Factory - Easy Fix???
rroe
30
NJ, USA
I bought an H Factory PAM 114 M2M recently. I really like it but to my eye the dial appears to be misaligned about 1 minute clockwise; that is the "6" should be where 29 is now. How difficult would this be to fix or adjust? Thanks for any advice.
D
d4m.test
Guest
The dial feet are either poorly aligned or bent. Once you uncase the movement, grasp the edge of the dial with your thumb and forefinger. Gently turn to the left. Be gentle or you will pop a dial foot. After you are done adjusting make sure the dial is not rubbing on the cannon pinion.
D
d4m.test
Guest
It doesn't sound like it from your info, but It could be that your feet are misaligned too badly to adjust. If so then you will need to pop off the dial feet and stick the dial on with scrapbook tape or dial dots.
