Sky Dweller Month adjustment
jeremyhuang13
OG and a Supporter
358
90
Anyone have Sky Dweller (gold) that is able to allow you to adjust the Month? I followed the instructions on YouTube of the replica and everything seems to work except the Month. The bezel turns but as you rotate though the date in the cyclop, the Month doesn’t skip over.....
jcguo0516
448
289
the month function is completely manual bro, just do it manually once a month, it doesnt actually jump with the date
Hazing
And So It Begins... Again
9/5/19
5,188
4,474
Reactions: KJ2020
37,544
80,313
Your model does not have an adjustable month indicator, it is fixed. Your bezel moves to three detented positions to mimic the positions of the gen bezel, however moving the rep bezel on your model does nothing else besides rotating its position. It's a useless function, but hey it appears to work like the gen so it may fool some of the people some of the time. Just don't show it to anyone unless its August, lol.
jb3md
826
345
Like kJ said - the DH gate reps are stuck w the month at August. Noob has adjustable month - see my sales threads I bought both!
Sent from my iPhone using RWI
jb3md
826
345
muiramas
Aristocrat
18/1/17
6,105
8,133
You’re in luck OP - just 20 days until you can wear it! Imagine if it was stuck on June...
Reactions: KJ2020 and Hazing
Hazing
9/5/19
5,188
4,474
So the bezel still turns and just does nothing?
jeremyhuang13
OG and a Supporter
358
90
I thnk you're right. I've been look at the threads and Youtube on how to adjust it. I know Noob Sky Dwellers allows you to mimic the gen like month adjustment but looks like mine is stuck in July. So this watch was new and factory just set it to August? There has to be a manual way to move it. Somehow it's set for August and now is July so soon I can wear it once a year!.
37,544
80,313
The new Noobs are the only ones the rep factories have produced that have an adjustable month indicator. All others ever made have a fixed month indicator ring (or no month indicator ring) glued to the backside of the dial. They are mostly all fixed at August, though I have seen some on DHgate where they are glued to a random month window. I modded one so the month indicator ring could be rotated manually but had not finished making it work without taking the caseback off. I'm glad Noob finally did this, it's a well executed feature. There is really no hope for you to ever move yours unless you want to devise a way to brute force jury rig it like I did.
jeremyhuang13
OG and a Supporter
358
90
Very informative KJ2020. Thanks you for the detail input. I am ok for fixed August date. I had hope mine was able to move the Month but looks like only th e Noob is able to do so.
Reactions: KJ2020
