seek comment for my tudor 7928
ken123
162
75
I found it from a antique shop and it costs around USD 900
the seller said the dial is rewritten and the movement is gen tudor 2824-2
I know it is defiantly not authentic but I think it is very gen -like
it has kif stabilise
Then , I took it for service and change a new dome. also sourced a Jubilee
What do u guys think?
p0pperini
patr0n h0arder
9,507
34,484
thank you. which image host do u use?
Sign up to Clickpix.org - it's been set up by our tech guy here Glaude, and once you've uploaded your pics you just need to copy paste the "bb code full" into your post. There's even a link to access clickpix directly, in the top right corner of the message composer window.
perfecto71
413
320
You can use the one built into the board by clicking the photo button with the blue plus or IMGBB is good.
jimcon11
159
97
Watch definitely has a lot of tells but it looks decent. The hour and minute hand are surprisingly close to how they should be.
If you're happy with it then that's what counts.
To make it awesome I would try to do the following: add chamfers to lugs, get a Vietnam dial, relume hands, replace seconds hand.
Reactions: ken123
ken123
162
75
thanks for your comment . where can i source the Vietnam dials and how about the insert?
Perpetual
2,372
3,627
Okay I believe I see 2 different watches here.... the first peice is nice passes for a phong case set and dial. The peice with the jubilee bracelet looks to be a cartel....
Sent from my SAMSUNG-SM-G935A using Tapatalk
Edit: okay nevrmind, I see what happened. The super dome needs to go along with the jubilee :D
Jingelee jangley jubilee Man!
Cheers mate nice pick up ;)
ken123
162
75
same watch
just changed the bracelet and dome
