Sea Dweller Decision
blass12
146
Hi all, just looking for some opinions as I choose between 2 versions of Sea Dweller to purchase.. I keep going back and forth on which one to buy, and just looking for any opinions or comments on which one you would choose.. Also any discussion on pro's & cons, I know each version has pros and cons which makes it a tough choice.. Also, for the most part I do not plan on modding the watch. Appreciate any input and discussion...
The 2 models I am deciding between is:
Sea-Dweller 2017 Baselworld 126600 904L SS V3 ARF 1:1 Best Edition Black dial On 904L SS Bracelet A2824 V3
Sea-Dweller 2017 Baselworld 126600 Noob 1:1 Best Edition 904L Steel Black Dial on SS Bracelet A2836 V10
Thanks in advance
Raddave
Administrator
67,017
18,639
2836 is a no brainer for me ....
Great movement , plus if you have problems you can swap it for a real ETA or Sellita
Reactions: blass12 and BrianU
SS72
2,982
10,249
Australia
From everything I've read, either moment should server to well and repairs/replacements won't be a problem either way, should it be needed. The 2824 is a slimmer movement and the stem and tube are in a different position in the case compared to the 2836. So if you ever need/intend to swap movements, it'll need to be a like for like, but both are available in abundance.
Movement aside, both reps are good. I was in your position a few weeks back, and I went with the ARF. The crown guards are way too fat (unlike the Noob), but otherwise a pretty damn good mimic of the real deal. And unlike other reps I have/have had, all the edges on this (band, clasp, etc.) are nice and smooth with no sharp edges. The Noob has its pros and cons, too. I'm very happy with my choice.
Have you read this post? It's a really good comparison between the two.
https://forum.replica-watch.info/fo...attle-of-the-sd43-s-126600-arf-v3-vs-noob-v10
Alternatively, the SD4000 is a good option, and this rep looks amazing: https://puretimewatch.io/sea-dwelle...ition-black-dial-on-ss-bracelet-a2824-v8.html
Reactions: blass12
blass12
146
https://forum.replica-watch.info/for...v3-vs-noob-v10
Alternatively, the SD4000 is a good option, and this rep looks amazing: https://puretimewatch.io/sea-dweller...-a2824-v8.html
Thanks for the info!
I may consider the SD4000, after thinking about it, I do not have a 40mm watch in my collection, most I have are 41-43 range, might be a nice change up... Had not even thought about the SD4000 before, wonder if its super thick looking at 40 x 15 though?
Hom
SD4000 is great, I'm a big fan of it. Some of the extra thickness is the protruding caseback which your wrist will absorb. With the thinner lugs it looks smaller than a ceramic sub on the wrist.
SS72
2,982
10,249
Australia
SD4000 sits nicely on the wrist. They're both awesome looking watches and if your wrist wears one well, in my opinion it'll wear the other just as well.
GrandmasterChime
Agent Provocateur
1,732
1,341
New Zealand
I have the noob sd43. It is impressive. I did the comparison when buying and I chose the noob because the 2836 has instant date change. The dial is more accurate ie marker shape and colour, red text colour, dial matt dial colour. The bezel is more accurate ie depth of numbers platinum filled, arf are deeper because the paint wears off. Bezel teeth arent as sharp. Either is good but for me those things were more important than the bracelet
Reactions: blass12
ciceroyeah
573
Anyone know if the sd4k v8 is actually still available? I've heard mixed stories from three trusted dealers, not sure I want to put down cash only to be told the factory doesn't make them anymore.
SS72
2,982
10,249
Australia
blass12
146
So I wound up ordering the SD4K & the SD43 Noob v10... Couldnt make up my mind, probably will keep one and sell one, or maybe will love both and keep em.. Will post pics
Reactions: GrandmasterChime
FRNOOB
68
12
Salut, je me dirigerai également sur le 2836, modèle "presque" indestructible avec des pièces facilement trouvable, n'importe quel horloger peut vous faire la maintenance.
