[SOLD] Sea-Dweller 16600 - BP Factory!
themaxx25
If you fall, I will catch you, I'll be waiting...
1,332
1,715
BP Factory Sea-Dweller 16600
CONUS first, then WW
Asian Clone 3135
M2M
NO
MINT
Funds
$295
$12
UP FOR SALE: BP Factory Sea-Dweller 16600
Beautiful example of a SD 16600 from BP Factory! Purchased M2M from @connery77. This Sea-Dweller has been a box queen for both previous owners, and same for me.
Statement from the original owner who purchased from Trusty:
Hey Guys up for sale is a BP Factory Rolex Ref.16600 Sea Dweller Classic in Asia Clone 3135 movement.
Watch runs and functions perfectly, everything lines up perfectly as well. I purchased this awhile back from trustytime, removed all the wrappers and checked for functionality but never used it. TWO EXTRA LINKS INCLUDED.
SPECS:
MOVEMENT: Nickel Plated Asia Clone 3135 Automatic Movement, 25J, 28800bph with fully decorated bridges/plates & rotor
CASE DIAMETER: 40mm
THICKNESS: 14.5mm (Exact Same Thickness as Genuine)
DIAL COLOR: Black Dial with Round markers (With Superlume Applied)
CASE MATERIAL: Solid Stainless Steel 316F
BRACELET: Solid Stainless Steel 316F with Flip Lock Deployant Buckle
FRONT GLASS: Sapphire Crystal (Same thickness as Genuine) - Etched crown at 6:00 position
CASE BACK: Solid case back
BEZEL: Uni-directional Diver Bezel, Anti-Clockwise (With Superlume on Bezel Dot)
HACK MOVEMENT: Yes
CLASP TYPE: Deployant Buckle
DATE INDICATOR: At 3:00 position (Adjusted via the crown)
Now, on to the pictures!
mclarendude
30,181
36,887
ATL
themaxx25
1,332
1,715
Dxp200
It takes a lot of balls to golf the way I do.
781
1,166
CONUS, FL
Reactions: themaxx25
Cormyr
25
Canada
themaxx25
1,332
1,715
themaxx25
1,332
1,715
Reactions: jduval
themaxx25
1,332
1,715
Reactions: Dxp200
