Screw pin or spring?
Offmybach
109
51
If case has one hole larger than opposing side, does that mean it was meant for screw pin vs. spring?
Sent from my SM-N975U using Tapatalk
Alhig72
2,774
3,960
It does but on ebay you can get spring bars that have a faux screw on one side and a smaller bar on the other side, i prefer these to a screw in bar but either is fine
Sent from my LYA-L09 using Tapatalk
Reactions: Offmybach
Offmybach
109
51
Thanks I will check it out.
Carbonara
1,538
1,568
Old Blighty
Offmybach
109
51
Here's my issue. I'm trying to attach the SS bracelet. The tube size is too large for bracelet opening. I think the screw pin alone may be too small? to keep end link properly seated. I see that tube is 2.6mm. I doubt I can find a 1.8 or 2.0 mm tube out there though.
