Sapphire Gasket Issue
bertieng
1,192
454
There are threads teaching how to thin up a gasket, but how about if the gen gasket is too thin for the retention ring to hold up the crystal tightly?
Most of the aftermarket gaskets only mention about the height but not the thickness.
In this sense, when those reps claiming to be 1 : 1 is not true at all......:confused:
8,205
You may want to clarify to help :
What replica you're working on, i.e GMT, Submariner,
Which factory it's from, GSC, Clean, etc
What parts you are using, i.e gen gasket + gen crystal or just gen gasket + deep crystal, etc, etc
8,205
bertieng
1,192
454
Thanks for your comments.
I am working on the BP Milgauss GV. Tried to swap out the stock crystal with the gen but the gasket is too thin for the retention ring to hold up the crystal, and it falls off. The stock gasket is green which is not correct for the gen spec.
8,205
Oh man you may have picked the hardest replica to franken... if I recall the ARF is the one you want for a franken base
