SA4130 crown/stem problem
Johnluuda
430
171
Hi guys,
After disassembling crown/stem on my SA4130 CF 116500, i can't not assemble it again on the movement because the marked pusher for stem did not go back all the way up. Can some one help me please?
domiffm
handsome
5,758
16,310
You must have pressed the button too deeply when removing the crown. You should only press it very lightly. By pressing too deeply, you screwed up the keyless works.
You must now have the keyless works reset. To do this, you usually have to take the movement out of the case and remove the hands and dial. Then you can access the keyless works and correct it. It is best to have this done by a watchmaker.
Johnluuda
430
171
Thank you
Reactions: domiffm
