SA4130 Chronograph's Second-Hand - How sweep is sweep?
tdx18
227
485
Cheers guys,
I've yet seldomly enjoyed the beauty that is the SA4130 movement, but everytime I did, and especially when using the chronograph function, I was kind of put off the tiniest little bit. It didn't truly look like a fluent motion of the chronographs second hand and only when really focussing on it I wondered: Is this supposed to be like that?
So, now I just took the ol' reliable smartphone camera and a x20 loupe and tried to capture this one and look into it in more detail. Attached is the respective video I captured. Lo and behold, time seems truly relative when slowed down so much, wasn't even sure the video was playing for the first second.
As you can see, the jumps of the seconds hand in sub-second paces is inhomogenous - there's two distances that this seconds hand travels alternatingly in (seemingly) consistent temporal intervals. So it might not be the actual beats, but the distance they travel with each beat, that created that impression of some-not-so-sweep chronograph second hand movement.
Now I wonder: Is this supposed to be like this or is it some irregularity with my particular movement? I do not have the necessary expertise nor the understand to fully understand how the chronographs seconds hand is integrated into the movement, so I'd be very interested to read some educated opinion in regards to that. For me personally, it is not a true issue. After all, the chronograph itself works pretty fine and has been doing so for a while a time and passed time can be measured rather accurately with this nonetheless.
alternative: [video]https://streamable.com/8fzmkg[/video]
Best,
tdx18
Rx4Time
Supporter, Panerai lover
12,148
11,223
Okay so I think what is happening is your video is actually showing artifact. Below is the same video clip of my genuine Tudor Pelagos. (That happens to be the watch I was wearing today). Notice how the full speed video it's smooth but as I slow it down you start seeing skipping and artifact.
As said can you paste a video running at normal speed?
tdx18
227
485
tdx18
227
485
Thanks for the reply.
First off: The video above wasn't artificially slowed down (well, in a certain sense it was), but was instead recorded @480 fps and then upon playback, it is stretched out to create the actual slow-motion. Attached here you find a short clip of the watch in regular temporal resolution. I feel that this effect is certainly less pronounced, but observable still. Of course this might be due to my own observation bias infringing objectivity here.
I'm quite fascinated by it, either way it's supposed to be like that or not. Cool stuff.
EDIT: Please forgive this severe case of vertical-video-syndrome. Guilty as charged..
Rx4Time
12,148
11,223
Definitely looks a bit choppy there as well. It should sweep fairly smoothly and evenly.
tdx18
227
485
And for the fun it bears, here is another one with the small seconds in conjunction to the chronograph's second hand for further illustration.
Luc.font
74
23
at a normal speed, it seems to be unatural sweeping, not something observable on this movement usually.
bc1221
4,079
456
It looks like it does stutter a little. May just be missing or worn down some teeth in the chrono gear.
Blackcalf
141
Madrid
Hi there
I saw same problem in noob v4 daytonas and now have same problem in clean 4130 as they use same movement. So every 1 from 5-6 watches came new with that problem, looks like some of gears aren't going well. I strongly recommend ask your dealer a short video with chrono working.
So would like to know if someone have a solution for this problem.
Thanks
Sent from my 2106118C using Tapatalk
madmex
136
12
I just received my clean sa4130 and it has the stutters seconds hand. In a 7750 and in other horizontal clutch chronographs there’s a coupling wheel that has space between the teeth to engage the chronograph. There’s usually an adjustment spring for this purpose, but in the SA4130 there’s a vertical clutch. I don’t have the technical documents for it but I’d like to see if this coupling is adjustable as it drives me nuts.
PsychoTee16
-- Watchmaker --
Vendor (Watch Repair)
1,264
1,024
Louisiana
The clone 4130 will suffer from this no matter what you do. There is nothing to adjust.
Rolex came out with a different tooth design that eliminated this problem. The LIGA wheels. Installing these pieces eliminates the stutter completely.
Reactions: AG91 and SuperLory
melody
335
141
North carolina, USA.
I know this is old but for people curious, the friction spring is all you need to replace to make it run like gen. It does exactly what the liga wheels do and eats up the backlash. Get a gen one super cheap. Liga are nice but they are not any smoother than it was with a new friction spring.
Seacol
Cheers guys,
Best,
tdx18
I have this exact same issue in 3 Daytonas/. Did you figure out how to fix it? Many thanks!
Seacol
I also have this problem with 4 Daytonas - I wish there was an easy fix- any advice is truly appreciated. Sucks to pay so much for clean or BT and not have the sweeping second hand.
AG91
121
35
I have a VSF 126500 with DD4131 and I bought the two liga wheels. @Johnny Depp is installing them and also a full service!
