Does anyone know if a SA3135 movement will fit into Noob v(#) with a case made for 2836 ETA ?
Interestingmember905 This member is doing hard time, they pissed off the goat. INMATE 26/10/17 113 13 0 11/5/18 #1 Does anyone know if a SA3135 movement will fit into Noob v(#) with a case made for 2836 ETA ?
trailboss99 Head Honcho - Cat Herder Staff member Administrator Certified 30/3/08 43,644 17,439 113 12/5/18 #2 smoke
Interestingmember905 This member is doing hard time, they pissed off the goat. INMATE 26/10/17 113 13 0 12/5/18 #4 smoke said: Nope won't fit Click to expand... thanks m8 saved me a good chunk right there
JMK Active Member 13/2/18 248 119 43 11/3/19 #5 What about the other way round? 2824 or 2836 in 3135 case? I assume I’ll need a retainer ring. Sent from my iPhone using Tapatalk
Perpetual I'm Pretty Popular 23/1/16 2,372 3,627 113 1/4/19 #6 Yes it is possible, movement ring needed raffles #2 ring should work
tony5haw2013 Active Member 10/8/19 405 61 28 malta 8/2/20 #7 The noob V10 sub takes both..i know because i have one and have tried Sent from my SM-G965F using Tapatalk
tony5haw2013 Active Member 10/8/19 405 61 28 malta 8/2/20 #8 The noob v10 sub uses the same case for all movements, they just use a movement ring for the 28xx movements. I bought a vr3135 and its a perfect fit. Sent from my SM-G965F using Tapatalk
V vibez Getting To Know The Place 21/11/19 32 10 8 21/4/20 #9 Does the zzf v2 2836 take a 3135 movement too? Sent from my iPhone using RWI
