Rubber gasket size for 44mm case?
Drulee
648
I would like to know the size of the gaskets that are used to seal the case and case back, also used in bezels, for the 44mm cases. If you have a few extras, that would be great, as I've just mangled one :(
Drulee
648
Has nobody ever bought gasket separately from the watch? Also what is a good gasket lubricant to use to help in water resistance?
Thx
Fiddo
Mythical
7,995
3,761
In a Causal Loop
I have never purchased a gasket spearately for a Panerai. I have purchased a couple of cases and they came with the case back gasket....which I believe is 40mm. Getat-watch dot com sells cases etc.
Silcone grease is used to lubircate gaskets to aid in waterproofing. Places like watchmaterial dot com and otto frei carry it. (ofrei dot com)
Drulee
648
I wouldn't suggest buying a case just to get a gasket, or count on the gaskets in the asian cases not to be damaged - if they're included in the first place :mrgreen: Lots of places sell the gaskets in bulk for cheap, few bucks for dozens. It's just a question of getting the correct size - inside diameter and thickness. I guess I should ask in the "mods/repair" section. Thanks anyway.
Woldemar
243
Hi!
Have you found the answer about the gasket? I'm also trying to find some info about backcase gasket for my 47 mm Pam Carbotech rep)))
