Rotor wobble 2824
Streetiq
345
139
Hi All ,
i recently purchased a new rep from my TD with asian 2824 .
all well and keeps good time, only issue is that when i move my hand i hear the rotor shaking in a weird way (shaking, not spinning)
oppened the case back and the attached video seems to explain my situation.
when i press down the edge of the rotor it moves up and down.. seems like it has clearence which make the noise (the screw is well closed)
https://www.youtube.com/watch?v=FL-MC4TKp84&feature=youtu.be
now, i like to hear your opinion guys,
1. do you think it is something a TD should spot in QC and inform me about ? or is it too common with the asian clones ? what would your TD do ?
2. do you think if i use the rep rotor i have but replace only the bearing to gen ETA bearing, the problem will be solved?
i found this listing from past posts here on RWI
https://www.ebay.com/itm/ETA-2824-2...270448&hash=item361978b023:g:d3QAAOSw7GRZLw8W
3. do you recomend replacing the whole rotor to a gen one instead of messing with the current one ? if so, does anyone has a source for gen fitting rotor ?
4. will a new rep rottor make the work ?
thank you !!
ThomasaurusRex
I had this exact issue with a seiko 5 and simply tightening the rotor securing screw in the center of the rotor did the trick!
Give that a go first before you take any larger approaches
Sent from my ONEPLUS A3010 using Tapatalk
Reactions: Streetiq
Streetiq
345
139
Thanks man, Yes I already did it but it didn't help.
I ended up buying Gen 2824 bearings, only the bearing and I found a Smith that is willing to replace only the bearing,
Will update in the future
Sent from my MI 8 using Tapatalk
Reactions: ThomasaurusRex
jerms81
371
47
USA, Texas
I had the same issue and contacted vac and got anETA rotor and bearing and it solved the issue.
Rx4Time
Supporter, Panerai lover
11,929
10,528
I think you'll have to replace the rotor as well as they are press fit. Personally, I wouldn't waste time to repairing it, I would just install a new ETA 2824 and wash my hands of the whole aggravation
Streetiq
345
139
Thank you guys, well where do I find a complete Gen rotor?
All on ebay seems to be Rep
yodog
Yo
3,616
1,751
In my parent's basement
you dont need a gen rotor, sometimes its the bearings on the rotor, and if that doesnt work change the entire auto wind assembly
