Rolex DD4130 parts upgrade?
wildrabbit
868
182
Hi Fellow Watch Fiends!
I recently bought a Clean factory Daytona with a DD4130 that I will be using as a donor to my Franken project.
Does anyone have a recommendation of what parts to change out with Gen to make run better?
On the old site there was a post about recommended parts to swap our for 3135's, but has anyone done this for a 4130?
Thanks in advance!!
Reactions: Kack 13L0CK3R
jeffm1000
179
292
What have you found so far? I've got one coming as well that I might consider modding. The bridge, wheel and screws are the obvious ones if you want it to look more authentic.
wildrabbit
868
182
This thread is digital gold: https://forum.replica-watch.info/th...-gen-parts-on-4130-daytona-movement.10817237/
Also - for reliability and performance:
Reliability Stage 1 - 815 (Clutch) + 880 (Hammer) + 540 (Reverser Wheel) x 2
Reliability Stage 2 - 145 (Auto Device Module) includes rotor + reverser wheels x 2 + intermediate wheel + driving wheel
Reliability Stage 3 - 315 (Barrel + Spring) + 204 (Angle Wheel) + 205 (Sliding Pinion) + 305 (Ratchet Wheel) + 834 (Jumper for Counters) + 201 (Winding Stem)
Performance Stage 1 - 120 (Balance) big upgrade over rep part
Performance Stage 2 - 360 (Second Wheel) + 820 (Chrono Wheel) Updated LIGA gears with special teeth very cool
Performance Stage 3 - 335 (Center Wheel + Cannon Pinion) + 340 (Third Wheel) + 840 (Minute Counter) + 825 (Intermediate Chrono Wheel) + 850 (Hour Counter)
Shock/Jewel Upgrade - 110 (Train Bridge) + 120 (Balance Bridge) + 190 (Chrono Bridge)
Feel Upgrade - springs and levers
Parts list:
120 Balance Bridge
880 Hammer
834 Jumper for counters
241 Yoke Spring
301 Click spring
110 Train Bridge
815 Clutch
865 Clutch Jaw
145 Automatic Device
360 Second Wheel
820 Chrono Wheel
190 Chrono bridge
860 Operating Lever
855 Column Wheel
432 Balance
204 Angle Wheel
205 Sliding Spool
305 Ratchet Wheel
315 Barrel with mainspring
856 Column Wheel Jumper
861 Operating Lever Spring
5855 Screw column wheel
822 Friction for Chronograph wheel
225 Spring for setting lever
201 Winding Stem
871 Spring fly back
butler182
648
669
Great list...thanks for sharing. I'm planning to undertake a similar project when my 4130 finally gives out. The original movement is still going strong after 2 years, even with no service after purchase!
Reactions: wildrabbit
MaximillianGT
2,954
5,668
49°50′34.8″N 9°54′07.4″E
Thanks in advance!!
Take a look at the balance wheel (432), there is a big difference between gen Parachrom hairspring and the rep one, the rep one can't adjust the wheel. Change this one is a good idea but it costs a fortune.
