Rolex Commando 6429 Franken build
369mafia
Resident Explorer Expert
3,981
7,954
Canada
A little over a year and a half ago I built myself a 6429 commando after stumbling upon examples online. Coming back to the community here I noticed a few attempts have been made with good results so I ordered parts and completed my build.
Fast forward to earlier this year and W124E reached out to me and wondered if I could build another. After some discussion we put together a parts list and we got to it.
GEN PARTS USED:
5500 case set
6mm crown
folded link bracelet / end links
crystal
Other parts:
Clone 2824-2
raffles movement holder - modified
ofrie handset
raffles DJ second hand
Yuki was MIA at the time so I reached out to Mochacha and received one of their dials. Good quality quite accurate nice lume work and has a nice puffy appearance.
2 criticisms on the dial
the paint is quite delicate compared to dials offered from yuki or raffles . the very outside edge of the dial chipped quite easily which was a bit of a disappointment It can not be seen when assembled but I expected slightly better for $400 dial
the dial plate was slightly smaller and although it fit the case , it just barely did. I had forgot to measure the dial or opening. I was just glad I was able to make it work
overall the dial is the closest there is to a gen example. He is now asking over $500 for the dial which I would say is where I draw the line If you must have one then yes but these doubled in price just over a year later is a bit much . ( I found out about them and this option just after I finished my build and considered ordering it as a replacement) but didnt. and probably wont . wish I did when it was sup $300
Once the parts arrive I went to work.
first to match the hands to the dial.
the seconds hand I had in the parts bit but it was slightly too short so I ordered the raffles dj
test fit the case and it is looking the part.
I buttoned up the build and let it run. I found that I was having an issue with the watch stopping intermittently
so I checked hand alignment. good
It ran fine with the crown uncrewed so that told me that the stem was either too long or binding on something causing it to stop.
The movement holder need to be modified I had machined down the flat side of the movement holder to lower its height to line up with the case groves . I also filed down the stem opening as well in order to provide greater clearance for stem operation .
once I got that sorted out , it ran great, keeping reasonable time and looking sharp. It was a pleasure wearing it for a few days , getting to enjoy it before sending it off to its new owner.
Did a quick shoot and packed it up and sent it off to its new home.!!
Overall I am very happy with how this build worked out. It was nice being able to see the mochacha dial first hand and work with it. The service from them was good and fast. Good communication and fast shipping . I would recommend them.
Thanks again to W124E for reaching out on this project.
I look fwd to future projects and builds.
cheers
freebalkany
316
355
Good job, I like it very much.
I see you wrote that the crown is 6mm.
Is the commando fitted with a bigger crown than the air king?
37,415
79,536
Very nice build bro and cool pics. I think the Mochacha dials are now being listed in CAD $, not US so the price increase may not be as much as you thought.
Good to see this rare example given some attention. It looks great with the camo straps.
Reactions: 369mafia
manodeoro
DO NOT TRADE WITH ME
3,986
2,603
YES they are ... nevertheless the Commando dial is listed CAD575 those days, so more or less USD450 ... ouch !!!
Reactions: 369mafia
369mafia
3,981
7,954
Canada
Yes the gen model comes with a 6mm crown iirc I cant recall where I read it tho..
jorry c
19/4/20
12
香港
Where to find the hands? Very good results:thumbsup::thumbsup::thumbsup:
manodeoro
3,986
2,603
ofrei.com ... HAN-6595 if I remember well (it's been a long time since I built a 6429) ...
I've searched for months until I found that set
- Hole sizes are H:1.50 and M:0.50 so they can fit an ETA without problem ... or an old USSR handwind movement (funny for a "cold war" US watch)
- Minutes hand is almost perfect as it's 12.5mm long (from center hole to tip) ... Gen is 12.70
- Hours hand is a little too long as it's 8.5mm long (from center hole to tip) ... Gen is 7.65
- lume holes start too close from the tube and are a little too thin compared to the total width ... you can enlarge them with an xActo but it's tricky
First pic is a Gen Commando, Second pic is from ofrei ...
W124E
100
72
Sorry for the delayed post, but the 6429 arrived last week, and whoo boy is it something! Thank you so much for all the help, 369mafia – this one is a forever keeper!
Reactions: 369mafia
369mafia
3,981
7,954
Canada
Glad it arrive safe and to your satisfaction!! It wears well on you !! Cheers!
