Rolex Classic Sea Dweller Ultimate Version with Superlume Dial----- 326usd
MOVEMENT: Nickle Plated Swiss Eta 2836-2 Automatic Movement with All Rolex 3135 Markings and Red Wheel, 25J, 28800bph, Perforated Rotor Design as per Genuine Movt
CASE DIAMETER: 40mm
THICKNESS: 14.5mm (Same Thickness as Genuine)
DIAL COLOR: Black Dial, Superlume White Dot markers
CASE MATERIAL: Solid 316F Stainless Steel 1 : 1 Caseset
BRACELET: SS Oyster Bracelet with Divers Extension
FRONT GLASS: Sapphire Crystal, Same thickness crystal as per the Genuine
BACK GLASS: Solid case back (Thick)
BEZEL: Black Diver Bezel Unidirectional Rotating
CLASP TYPE: Flip Lock
DATE INDICATOR: At 3:00 position (Set via Crown... Chamfered Date Window)
CASE DIAMETER: 40mm
