Rolex 3187 problem in Noob GMT Master II
alexmenn
14/8/19
14
HI all! I received my brand new Noob GMT Master II 116710 LN . It was running perfectly 2 days, but yesterday I changed the hour again to adjust 2nd local time, and the hour hand jumped a bit and now minutes and hour hands are not synced, same for GMT hand. Can I fix it myself without open the movement or have I to go to a watchsmith? damn it... I should never change the hour :(
Check that the GMT is not synced too, because the bezel is not aligned (I will fix it reinserting the bezel this week).
I've tried to realign hour hand with 2nd position of GMT, but without success, it jumps every time foreward or backward.
tripdog
Super Moderator
25,226
24,283
It's broken - AFAIK nobody ever came up with a solution the problems with this POS movement.
alexmenn
14/8/19
14
I will check it with my watchsmith, maybe he can fix it, because its a overjump of the hand
alexmenn
14/8/19
14
A question, if the mvt is broken, can I install a 2836 or 2892-2 inside? And change the hands order to ICHS. Or I need a new rep?
tripdog
Super Moderator
25,226
24,283
You can install a new movement, but this will change the hand stack, so you'll need a new GMT hand .
alexmenn
14/8/19
14
Ok, then I can install a "non decorated" 2836 with working GMT and different hand stack, but only if Ig a new GMT hand compatible, right?
Do you know where can I buy one?
Rx4Time
Supporter, Panerai lover
12,254
11,583
Just sell it for parts and buy an ICHS movement GMT replica.
