Hi guys,
I have a question that I couldn't find the answer for on any of the rep fora. I'm thinking of replacing the helium valve escape on my 5GPO with the one from my 45.5 UPO. According to R2D4's reference guide, the 42mm and the 45mm PO's use the same HE valves and HE tubes (they also use the same crown and crown tubes in case you haven't noticed). I assume that the parts are thus exchangeable.
However, I have not found any tutorial on how to disassemble the HE valve. I tried simply unscrewing it all the way but it gets stuck and I do not want to damage it by forcing it. Is there a way to disassemble it? and Also, does anyone know if the HE valve can simply be switched or if the HE tube also has to be switched together?
Thanks in advance for your help,
Daniel
Daniel
