I was wondering if anyone had a place to purchase spare lug screws for the 111n v3, lug width 24mm?
I also read about people converting to springbars and just wanted to get some input on the pro/cons of doing so. Im assuming that standard 24mm springbars should do the trick or maybe even fat springbars...not sure of the fitment of those.
Do you guys also use loctite for the lug screws or is that not neccesary seeing as the tube should help from un-threading?
Thanks in advance for the input.
